Hello All,
With the help of a friend we swapped my dead 99 injector pump with a donor from a 2001 ram.
I was happy to hear the ole rusty Green Monster rumbling again after the 6 hour swap.
It has been sidelined for almost 2 years...
At startup, it was responsive to throttle and the rpm showed on the dash tach. My grin was from ear to ear!!
Sometime later I heard a slight brief cough from the idling engine and discovered the dash tach at zero and the throttle barely responsive.
Pushing the pedal gave a momentary increase and then nothing throughout the range of pedal motion. Just a smooth engine idle.....
That was yesterday. This morning I started the truck easily and had both RPM and pedal control as expected.
I went inside to let it warm up and had returned to find the same weird change. No indicated RPM on the dash and the same odd pedal response.
All the while a nice smooth sounding idle from the beast....
I waited a bit and returned to try the test again, this time with the code reader. On startup (engine light has been on since the first start):
P0238,0122,1698,1689,1688 and the antiskid warning light.
I cleared the codes and restarted. No initial engine lights or antiskid warning, normal indicated RPM on the gauge and correct throttle response.
I had to leave at the point and will have to restart the testing Sunday morning..
Any initial thoughts from the members?
(my initial search did not find an appropriate thread on this topic. If anyone wants to point me to one, thanks!!)
David
David
