I have heard a lot of talk about changing from the stock injectors for power increase. Now I am wondering if an injector swap will add power to an otherwise stock motor? No box, no boost fooler just stock. I am new to the diesel realm, but I don't see how this is possible unless the injector pump is instructed to deliver more fuel to feed the larger injectors. Is there something I am overlooking here? Has any one (customer or supplier of aftermarket injectors) performed and dyno tests after installing larger injectors on an otherwise stock engine?
I was considering a mild upgrade such as 275-300 hp rv injectors.
