Engine/Transmission (1994 - 1998) Injector question??
Engine/Transmission (1994 - 1998) 370 Marine Injector hole size?
Engine/Transmission (1998.5 - 2002) Flywheel bolts????
I have here some injectors, numbers on them are KDAL 59P 6 260bar Bosch Germany 368 - engraved in an oval is 060 , on the top between wrench flats is 6818. ANy idea what these are, I know they are out of a 12v, just don't know what hp. Thank you, marc
I will try Cummins in the morning. We went to measure the spray holes tonight and got kinda side tracked with the pulling tractor instead. My thought is to open up the holes on these and see how the spray pattern is versus 370's... ... Thank you much, Marc
