Engine/Transmission (1998.5 - 2002) Injector question
Engine/Transmission (1994 - 1998) '94 NV4500 Lost 5th Gear
Engine/Transmission (1994 - 1998) help me plz
Absolutely. There are many different opinions as to what's a safe HP increase on the stock turbo, but personally if your doing any kind of real towing with your truck I personally would not do anything over +60 horse injectors unless you plan on upgrading turbos as well. The RV275s are +40 HP, made by Bosch, and are a good quality injector that will last as long as the OEMs. There are also some good aftermarket jobs but do your homework to make sure your buying a clean injector.
Yes, I run the RV275 injectors and boost fooler elbow with no chip. Works great for me............more power, quicker spoolup, 30psi boost, great for hauling & towing.
You will gain some but not a lot without extra fuel. Even 100 HP injectors do not gain a lot when the fueling ramp is stock. You need something to ramp that fuel curve up and reduce the TQ management.
