Harvey,
From what we have seen over the last two years with fuel filters on the Class 8 trucks I have decided that there is a fine line between protecting the fuel injection system and having a fuel filter that plugs on the second trip to New Jersey in one week. We seriously had people in 2007-2008 that could not run a full week on a primary fuel filter, drivers were buying 6-8 fuel filters at a time to carry with them. The filters were too fine. The predominant set up for filters now from the factory is a 20 to 30 micron Racor fuel/water separator mounted to the frame and then the standard fuel filter specced by that engine brand mounted to the block. That seems to be working better.
It wasn't too bad if you had a Cat, but Detroit, Mercedes and Cummins went a little too far with the original spec for the primary and learned a lot in a short time. :-laf
They had good intentions and were trying to protect the fuel systems and regen systems. The trucking industry has been slammed trying to cope with the EGR systems, regen/aftertreatment devices, ultra-low sulpher diesel and now the Urea treatment coming out in 2010. Diesels used to be simple, eh??:{
Not related to this thread but this thought just popped up in the old cranium,
Big Rigs carry 200 to 300 gallons of fuel. Up to 90% of the fuel delivered to the injectors is returned unburned to the tank. If we spec a truck with a single tank (100 gallons or under) a fuel cooler is mandatory and is added by the factory. Are our 34 gallon Ram tanks getting the fuel a little hotter than it should be under certain conditions?????
