BDaugherty
I realize that there are a couple of similar posts right now, but they are dealing more with the FCA.
My question: What is injector rattle? What is the cause and when does it warrant injector replacement?
I notice that when I run my truck up to 2100RPM or so and then shift gears, I get a clatter before the RPM's drop. It's worse cold and also worse if my TST is adding any timing. The sound that I'm referring to is distinctly different from the sound the engine makes with added timing when cold or under load.
