Details here: TDR Privileges
Is it possible to install 25hp nozzles onto my stock injectors? If so how difficult is the process? I’m have long crank times and have replaced the lift pump a few months ago along with new batteries and new fuel filter. <O</O
Yes, But I doubt it will change your long crank times... Yes you can do it yourself. Although People send them here all the time after much frustration of self-doing.
There is a lot more to the injector rebuild than the tips, which, is probably not the source of your long crank problem. You really need to send/take them to somebody that can test them out and replace the injector if its bad.
