injector removal
Valair Clutch purchase????
Emissions
i have 08 dodge sitting at stop light check engine and lightning bolt came on now has steady miss cold it be bad injector if so how hard is it to replace
Is it out of warranty?
The injector is probably easy to remove and reinstall but knowledge of the correct procedure is required. Unless you are a skilled mechanic with a service manual with instructions I would not recommend it.
