Okay,
So I tried an injector return flow test, at least the way that I thought you were supposed to do it. I am not sure if I did it correctly, but here is how I did it.
I assumed that we are trying to just isolate the injectors so that we are only getting injector return, not cp3 return, etc.
Not having the required miller tools, I used an m12X1. 5X20mm bolt as a plug in the front filter housing banjo bolt location. This is the line that comes off of the top of the rail pressure relief valve and ties into the CP3 return line.
At the rubber hose connection on that same line, I took off the factory rubber hose and made the return line coming off the CP3 run into a catch can. The other end of the line the one I plugged that comes off the rail relief valve, I left the end where the factory rubber hose was just open because my bolt should have plugged it off.
Then I routed the fuel line that comes off the back of the motor/head and returns fuel to the tank into the graduated cylinder (a quart oil container with 'ml' measurements on it).
This was my attempt to isolate it to just the injector return. I think I did isolate it to just injectors.
I then had the truck close to temp, about 140*F and started it, started my timer, ran it for 1 minute, shut off truck, found that it does way less than 180ml, more like 80ml.
I found that if I added the CP3 return to the 80ml injector return, I had about 280ml.
Did I do this right? If I did, then I am assuming that my return flow is within spec, and my injectors are fine.
I did all of this because of a rough start/idle smoke for 5 seconds problem I had been having. Look at this link here...
Bad FCA, Injector, Rail pressure relief? - Page 3 - Dodge Diesel - Diesel Truck Resource Forums
