Engine/Transmission (1998.5 - 2002) injector swap and valve adj.
Engine/Transmission (1998.5 - 2002) Warranty update?
2nd Gen Non-Engine/Transmission New Truck
Within the next couple of weeks, I'll be switching back to the stock injectors. Since I've also got ~85,XXX on the clock I was going to adjust the valves. The question is, with the injectors out, will the engine turn over easier like a gasser without the plugs in it? Thanks in advance. Eric
It also turns over pretty easy with the injectors in. I have always used the alternator nut rotating the engine backwards.
Jim
