Engine/Transmission (1998.5 - 2002) Injector Tool ???????????
My mechanic just called me and said He didn't want to try pulling out the injectors (for my rv275 nozzel swap) because he said it looks like you need a special tool to get the injectors out of the head. Does any one know the PN to this tool and do I have to go to Cummins to get it?
Thanks
Walt
All you have to do is pull the injector line away from the connector tube, then use a small screw driver to pry the connector tube out, (its held by an oring), then screw an intake manifold bold into the top of the injector, and use a large pair of needle nose pliers pry the injector out, using the rocker arm as a pry-point.
One of the bolts from the intake air horn (the one the intercooler boot connects to) and an angled pair of needle-nose pliers is all that is required to pop the injectors out.
Rusty
