THe PODs (Prince Of Darkness) are in reference to Lucas lightning that a shop had that constantly left them in the dark. Forget who it was, but they post here. 4 hole tip; sac type (not sure about this, please clarify, pastor) PODs add 50hp/ 105lbft to intercooled trucks; 28(?) hp/ 55lbft to non intercooled trucks, or somewhere thereabouts. I guess that would be at stock fuelling? Or is it regardless of pump settings? Seems that more fuel per stroke would net more power (increase) than stock settings. Smoke like a freight train at more aggressive fuelling.
PWs are the Power Wagons, aka Bosch 185s. Now more expensive than DDs were, or EDMs are now, thanks to price gouging by Bosch and Dodge. 5 hole tip; one less than stock intercooled; one more than stock non intercooled. PWs add about 30hp/ 75(?)lbft to intercooled trucks. They are about even in non intercooled trucks.
DD- Diesel Dynamics. No longer made for first gens trucks, or so I've read here. Tips formed by extrude honing- running a super fine abrasive through the spray holes in the tips to smooth them out and make them bigger to flow more fuel, with better atomization and less smoke and EGT. Came in varying levels- I-IV, I believe they were, as memory best serves. DDIIIs out flow PODs.
EDM- Electronic Discharge Machining. Starting with a BLANK tip, they use a tiny electrode to cut holes in the tips at angles and numbers to match the engine design and power desired. They are made of an alloy, and are harder than stock Bosch tips, needle seats better than stock; usually have more holes, making a smoother spray than Extrude Honing, or so I've been told. Come in "Mach" series- Mach I, II, III, IV, etc. Supposed to reduce EGT, add bottom end torque, and increase MPGs. Guess I'll find out next week- have a set from Rip Rook on the way- ship Friday or Monday.
Some of the performance injectors have a higher pop pressure than stock; effectively retarding timing, or more correctly, the time injection into the cylinder begins; so a timing advance of a degree or two may help reduce smoke and lag, if needed.
That is my knowledge of First gen injectors. Please feel free to add, clarify, or correct anything I may have missed or messed up.
www.dieseldynamics.com
www.f1diesel.com
Daniel
