Engine/Transmission (1998.5 - 2002) Injector Washers??
I'm getting ready to install a set of used Bully Dog Injectors, Stage 2, and I need to know what copper washer to get. Can I use new stock ones or do I need ones from Bully Dog? If I can use the stock ones, what is the going price on them. The dealer quoted me at 4 dollars a piece.
Do I also need the O-rings? These used injectors only have 5000 miles on them.
Thanks for the help in advance,
Matt
I'd get the washers from Cummins, if you need to at all. That is, unless for some reason Bully Dog has special washers? Anything's possible?
As far as changing the o-rings, if they are smooth, nic free and plyable why bother looking for trouble? I've swapped injectors with far more miles and had no problems at all - even using the same seal washer that was on them.
