Other than the truck not starting what is the best way to tell if your injectors are air locked?
I was driving along in my truck today and pulled off to grab a little lunch from a drive through when my truck just stumbled and died. It would not restart.
I can bump the starter and here the pump run but the pressure is really low. . Only about 5 psi max and that is building up from about 2 or 3 when I first tap the key.
My injectors, comp, gauges, and weber fittings all went in a little over a week ago.
When I first got my truck back the fuel pressure was nice and high. . about 14-15 all the time. The last several days it has been about 11 to 12ish. .
Bumping the starter I get a small drip of fuel under the truck so there is a small leak somewhere that may have been bleeding pressure and let air in. I am un sure...
any ideas?
thanks.
any ideas?
thanks.
