Engine/Transmission (1998.5 - 2002) injectors are in WOW
well i installed my jammer 5 nozzles and wow what a difference. for those who are wondering i did the nozzles myself goes easy take longer putting the injectors in the doing the nozzles. anyways wow these things make a difference may truck has a little lope now but i think that the hot rod vp. the only thing is im having a starting problem after the truck sits. is this bad orings again like it was the last time i had this problem or is this something to do w/ the injectors. the install went pretty smooth except for #5 wich did not wanna go it at all. ended up forcing it in(i know not good but... ). anyways these things really make the truck scoot and smoke wow w/ the big pump a slow turbo and these babies oh man i can smoke. :-lafOo. :-lafOo. :-laf.
How are your egts with the 5's?
a hard run i could start to get over 1200 but it i had to back out at that point so idk how high they will get.
as far as the leak problem ill have to check later i got a really bad tank of fuel and have other issues that maybe have some how contributed.
It sounds like you had the transfer tube hold the injector up. Mine did that on #6.
If you have a leak on the high pressure side it will cause a long crank start condition after sitting.
If I were you I'd pull #5 injector and the transfer tube to make sure that your not adding thin oil to your crank case. Forcing an injector down is a no-no. You can use a small screwdriver to leverage the transfer tube out enough for the injector to "drop" in.
Mike
the tube was plenty out since the injector slide out no problem the new one wouldnt go in. also i slide a screw driver and felt around and everything felt clear and fine
