Injectors, Brand new POD,s Idle?
First Gen Cummins Part number for piston lift pump?
Hydroboost and starter
Hi guys finally got a brand new set of Delphi POD injectors at a screaming deal 255.00. My idle has changed, like I need to adjust it up, its now to low! So I guell Ill do that unless someone tells me different!? I did adjust the throttle pedal, since for years the angle going down the highway wears out my foot!
You can do that one of 2 ways, you can turn up the idle stop screw which is the safer way to do, or you can very slowly run in the fuel screw little by little and bring up the idle speed that way but you can potentially cause over fuel that way.
