Archived injectors leaking after install
Archived help with starting issue
Archived check gauges light,no amps
well I got rough running problem fixed I took out all injectors and redid install but now it seems like all injectors are leaking at the 19mm nut could I have overtightened them I had 1 lose and it was leaking bad and running rough I tightened and it went away but I cleaned off motor ran down street and it is wet under each injector I have changed injectors 3 times now and never had a problem till these
I had the same problem with mine after my install.
Try backing off the injector line nuts again, loosen all the injector line hold down clamps. I would look at the condition of the ball ends where they meet the injector tubes for damage and corrosion, then wiggle & re-seat the lines (19mm nut ends) where they bolt up to the head. Tighten the 19mm nuts first, then tighten the hold down clamps.
It may be that you will have to replace your injector tubes.
