Injectors next ??
valve covers leaking
brakes pulling
Ok I need input from you guys, I have been adding power as budget allows, check my sig. I think injectors are the next step. Maybe DD II's ?
Or should I go to DD III's so they are in when I decide to hook up the pump wire. Thanks in advance for any input.
Brett
I cant cure this bombing virus. :) :)
Brett, I'd upgrade the clutch first, then tap that VP44 wire and go from there. I'm running a McLeod Dual disk and have no complaints as it hold all the torque I can make. While I like the Mcleod alot, Peter at Southbend Clutch also makes a winning product for your vehicle, for less $$$ than the McLeod. Do a search under Southbend Clutch and be prepared for some reading as there are many happy members here that have them . If you are interested in the McLeod, talk to these folks http://www.jvdeng.ws/ at JVD. The last time I checked, they didn't advertise the McLeod on their site but it's worth the call. They build each clutch and TQ test same before it's shipped.
Scott W.
