Injectors
Found 50 Dodge/Cummins trucks for sale
What size Bolt?
What is the difference between 275 injectors and the DD1 injectors,and what performance gain will I see with either one.
I will also be adding a boost module,and Van Aakens is allready on the truck,just trying to get an idea of what kind of performance I will get.
The trans will be upgraded as soon as DTT vb and tc gets here. This truck tows 90% of the time and want the piwer to be there and also some decent mileage. . Thanks
David Foster
Dave, IF you put your truck & trailer stats in your signature ( profile ) you would not be asked to enter it when you post. What type and size trailer do you tow and where do you tow it.
The DD1's will add about the same power that the VA did. With any injector upgrade In combination with the VA it will smoke at low boost. With any inj upgrade you will need a boost elbow and module, If you HAVE to run a box with the injectors you could get one with a built in boost module, cheaper, but remember if the box dies so does your boost module and with upgraded injectors you will set codes and defuel over 20# boost.
If you get the DD3's you will have about as much power as DD1's with a box but for 1/2 the money. more bang for the buck with lower egt's.
You will be amazed at the increase in performance with the DTT upgrades
I have a VA and a PE-EZ but I do not use them for towing, just for some TDR get togethers and crusing.
Don't neglect to upgrade the exhaust system as MO POWER= HIGHER EXHAUST TEMPERATURES.
2K, 2500, Quad, SB, 4x4, 3:54LSD, A/T, REESE 15k 5th slider, EASLEY BULL BAR, MAAP NERFS, BFG-TA's, 9000's,TORQUS MAXIMUS 505 lbft ECM, stealth DD2's, Bully Dog Boost & elbow, ISSPRO pyro, boost & transmission, Turbo Lifesaver, JARDINE 4", DTT VB,TC,TC SAVER and AUX COOLER, PAC BRAKE, MAG HYTECH TP& DC, AFE filter, GEAR VENDORS OD onboard. Taylor Wing on order
pullees:
#1 y2k ARTIC FOX 5th
#2 22' car hauler w/ 76 Pinto 392cid or 68 Cyclone GT Cobra Jet FB
NRA-LIFE, VFW-LIFE, SoCSA-LIFE, SASS
[This message has been edited by JNutter (edited 03-21-2001). ]
