Injectors
SPEED
Clock Spring Replacement
Which injectors seem to work the best with the 160hp pump? i'm already running a #6 plate. I have read alot on the dimond b 300 and 370 will these work with my truck? or will i have to pump mods?
The 300 and 370 are bosch right?
What is the bosch part number for the injectors?
Thanks
adam
"POWERSTROKE THIS"
Adam Harman
95 auto red and white #6 tst , eagle alluminum wheels. Stright pipe, Still BOMBING
Adam:
The 370 Diamond B Marine Injectors are
made by Bosch. I have them in my truck
but I have the "180" pump.
I believe you are correct on the "160"
pump having to be "modified" to be
compatible with the 370's. "Koa Man",
Piers or Joe can tell you exactly why
the 160 pump needs the "mods. "
I ordered mine from Piers at "BD",
however, Joe Donnelly can also get
them for you. There are about 5-6
different 370's so be careful. Some
of them do not work well and I believe
Piers tested all of them when he was
researching the best combination.
I do not have the part number but
Piers or Joe can help you. Piers can
be reached at: 1-800-887-5030.
John_P
Red '96 4x4 2500 Auto 3. 54, TST #5, Major Pump Mods(By "Scheid Diesel") 370 Diamond B Injectors, Gov. Spring kit, AFC Spring kit, Banks Exhaust, Prime Loc, Cummins Chrome Kit,Psychotty Air Filter, Pro-Torque Converter, BD Valve Body, BD Pressure Loc, Isspro Gauges, Sendel 16" Alum Wheels w/ 33" BFGs
