If I added a bigger LP could I run 150hp Injectors with my setup???
KWheaton said:I've discussed my turbo options with my mechanic friend on numerous occasions, especially when I was doing all my upgrades. He said, install the injectors, AFE, exhaust and Comp, then see how it performs. I did, I tow heavy (12k lbs. ), I've watched my egt's on long climbs in the hot summer. I've seen 1200 degrees for short periods, it will get hot if I let it. Usually, keeping the O/D locked out till 60-65mph does the trick when towing.
Every truck is different, you want horse power, you won't ever tow heavy, get the turbo too. Do your other mod's first, drive it, then order the trubo. A bigger turbo, when lit, will really open your eyes and sit you back in the seat. Another thing to consider, boost pressures. You'll have to set the wastegate to less than 50 psi to protect your head gasket. Hy35 is efficient to around 38-40psi, and I can see pressures approaching 45-47psi. A bigger turbo might be efficient to 55-60 psi and needs to be wastegated. Head studs and ringed head is more than I can afford. I also want longevity out of my engine, more hp won't give me that. The bombing bug is fun, but an expensive and sometimes slippery slope.
Have fun! Thats the point!
My next move, upgrade my COMP to DRAG!!
P. S. With 400 horses, you'll need a full trans upgrade. I could drive right through my old torque converter when I was stock! If you get the chance, drive a truck thats had a fully rebuilt trans. , you'll be amazed.
