The differance can be how many holes the fuel is pushed through to atomize it, how big the holes are, and at what psi they will pop at. The numbers you refer to would be what HP the factory motor was rated at that that particular part # injector came on. On a motor with a differant cam, piston shape, computor program, or compression you will get a differant result.
