injectors
thanks
Another New Member
I have been having a problem with low (to me 20-30 degree) mornings with the truck losing a cylinder and really shuttering. It appears to be the number 2 cylinder but can't be 100% Is this a sign that the injectors are dirty/wearing out? If so is it worth it to have them cleaned or will they constantly give me problems.
If I need to replace injectors I will go the aftermarker route. From another post it sounds like Diesel Dynamics is building the injectors I would like; no smoke and 300hp. Will my auto hold this? transmission was rebuilt under warranty at 75k.
I would go under the hood when it's missing, and feel the exhaust manifold. See which cylinder is cold, or cooler than the rest.
One of those fancy infared thermometers would be handy for this.
How many miles you have on this truck? I guess you could have a clogged injector, but I feel this the exception, rather than the rule. I am by no means an expert, but I just dont think it happens that often.
If one cylinder is colder than the others, I'd probibally be looking at the injectors too I suppose.
Also, you can crack the fuel supply lines when it's missing (beware of very high pressure) and see if youre getting fuel to the offending injector. If youre not getting fuel, look at the inj pump.
Eric
98 Quad cab 4X4 2500 12 valve,5 speed,3. 54 rears, 8' bed. Michelin 275 75 16 lr-E. Boost and egt gauges but basicly stock except for a "properly adjusted" AFC. Cat in the garage. Uniden HR 2510, Texas Star 1200 amp. 63,000 Mi as of 1/27/01.
NRA life member. High power/IDPA.
Oops forgot my signature.
I did feel the exhaust that is what makes me feel that it is the #2 cylinder but by time pipes get hot all cylinders seem to fire so that is why I am unsure.
Oh I still have the cat on my truck but mileage seems good and I would think any effect the cat would be on all cylinders.
Eric Kelcher
92 W250 stock 4spd/auto 3. 54
96 2500 extd SLT Diesel Dynanics fuel pump plate; auto with DD shift kit(?) Dun-Rite TC; 3. 54 posi; K&N airfliter; Boost, transmission temp, EGT guages waiting for nice day; 192K
13. 5k 33'utility trailer 19' Galaxie runabout
Eric:
With all your transmission "upgrades"
I would say you could easily handle
"Diesel Dynamics" injectors. It looks
like you have a similar set-up to my
auto and I have had the 370's for about
six (6) months now.
You will really notice a BIG difference
in the power!
John_P
Red '96 4x4 2500 Auto 3. 54, TST #5, Major Pump Mods(By "Scheid Diesel") 370 Diamond B Injectors, Gov. Spring kit, AFC Spring kit, Banks Exhaust, Prime Loc, Cummins Chrome Kit,Psychotty Air Filter, Pro-Torque Converter, BD Valve Body, BD Pressure Loc, Isspro Gauges, Sendel 16" Alum Wheels w/ 33" BFGs
