injectrs
Using oil!!!
fuel leak at rail pressure relief valve
OK GUYS,
Time for new injectors. Looking at BMS 50HP with the 143 spray pattern.
My truck is an 03 305hp with a nv5600. No tuners etc.
I know Cerb did this a year or so ago but did not see his final thoughts.
Is this still a good choice if I do not have any additional tuning/modifications. Three stages of filtering are now in place, but not quickly enough. Only 95,000mi.
I do not care about power, but good mpg is nice.
Thanks
K5IP
Yep, can't beat the price point and performance on the 143 BMS 50's. On the engines with the bowl matched for them you will have no issues. I ran them on an 05 and even stock they were fine, better when tuned. Mileage is pretty subjective to how the truck is driven, YMMV. Tuning is still the best way to increase efficiency but they should work even stock. Mpg may go up from worn injectors for sure.
