2nd Gen Non-Engine/Transmission Inop Dash/Tail Lights
2nd Gen Non-Engine/Transmission ABS CONTROLLER Where is it?
Engine/Transmission (1998.5 - 2002) VP-44 tech question...
Anybody know the fix for no dash, overhead marker, tail, and park lights? My headlights, brake lights, turn signals, and emergency flashers work but nothing else. Even all my trailer lights went out except for turn signal, brake, and emergency flashers. Checked all the fuses and they were okay.
Elk Hunter
Update :)
Thanks to everyone who passed on some information. I used everyones advise and traced the problem down to the switch. The switch evidently overheated the pigtail and burned the B2 wire. I had to install the same switch, the dealer wouldn't sell me one of the new switches going into the 3500s on their recall.
Thanks again everyone,
Elk Hunter
It may be a wiring problem then. Pull a bulb and see if you have a ground connection. Then start tracing wires for the park lamp circuit.
Have you checked to see if you have power at the fuse? I think you probably burned up the headlight switch and connector.
If you are driving a dually it may be covered under a recall. I have a 2500 but for the improved wiring i used the recall set up on my truck. It adds a relay to remove the park lamp current from overheating the headlamp switch and wiring.
Bob
