Considering adding a lock-up controller to my 47 RE Auto Transmission. Curious as to how many have broke the OEM Input Shaft & how? I have heard conflicting reports regarding the use of lockup devices & the OEM Input Shaft on the automatic transmission. I have been told that there is a approx. 27% failure on the OEM input shaft when a lockup controller device is installed. I have also heard that under routine normal driving that the OEM Input Shaft will be fine if under 350 RWHP. I am considering adding a lockup device & exhaust brake & would like to hear your experiences good & bad. My intention is to be able to lock up 2nd gear when needed & to be able to run an exhaust brake when pulling. No lock to lock shifts or drag racing\sled pulling as this is my daily driver.
Thanks,
Clay.
Thanks,
Clay.
