Inside cab fast idle adjuster
Fan idler bearings?
Something New
Does anyone have the dash mounted idle adjuster found on some early model 89/90 CTD's? I have seen the parts manual breakdown of this but nothing is offered (as far as I can find out) as a unit. The mechanism mounts onto the bracket on the firewall next to the foot pedal and has a cable that goes to the dash. I assume it has a twist lock cable and lets you raise the idle speed so you can operate some power take-off equipment. Any advice would be appreciated. Thanks in advance.
My 89 had it and it worked great!!! worked up to 1400 Rpm. I wish I had it for my 93, it was a full pedal replacement part,but I don't think you can order it anymore. Right now I've installed an electric idle solenoid to have an 1100 high idle for the morning.
J-eh
It is basically as you describe it. It is mounted on the dash over the go-pedal and it pulls out and twist-locks into place. The cable goes under the dash and hooks to a medal bracket the holds the pedal where you put it. Really slick. Use it all the time. I replaced the cable about a year ago from the dealer. The only other part is the metal piece that goes behind the pedal. Maybe try a junk yard.
