SOLVED!: Install of Bypass. Motor now "howells" under load above 1800rpm
I've installed my bypass just like this one
https://www.amsoil.com/bypassfilters/2005_ram_cummins/index.aspx
however, I moved it closer "up" in the same spot and my return line rights directly right and follows "up" the valve cover to the oil return
Anyone experience this?
EDIT:
I did drop a fitting some place in the chassis, directly down from the top of the by-pass. if anythig it would of gotten in the spring/shock area or under the turbo. nothing in anyplace that would "move" like the fan. not sure if it came out, not in my driveway or garage
EDIT:
