Install of gauges.
Installing a 3rd Gen Radio Antenna on a 2nd Gen Truck
Piers Diesel Research (PDR) Troubles
Can anyone give me some hints before i drill into my perfectly good manifold to install boost,egt gauge inputs. I have bought some used gauges and don't have any install instructions. I'm sure there is a past issue that goes through it step by step. :confused:
Try the search function with the key words "gauge installation". There you will find plenty of instructions and also helpful tips. . :cool:
Good luck, Phil :D
This link will get you started: Install
What year is your truck my truck already had a plug for the boost gauge from the factory in the intake manifold. As for the EGT probe the exhaust manifold has a web in the middle so you need to drill a little off center perferably towards the firewall as I believe these cylinders run a little hot. As for drilling take it slow cast iron drills and taps very easily. Stop and clean your drill bit off a couple times before you drill through before you drill through put some grease on the drill bit this will keep the chips on the drill. When you break through use a pen magnet through the hole to get out as many chips as posssible. Then tap the hole use grease on the tap this will keep the chips on the tap. After tapping use the magnet again and get all the chips out. Look in the hole with a pen light and see if you got all the chips. Make sure you tap it deep enough to get the thermocouple into the exhaust stream about half way but don't tap it to deep or the treads won't seal off and it will leak. This is for the install before the turbo.
Coffee Nights in Derby, CT
Miller, Were are you in CT? A large group of guys (or is it a group of large guys :rolleyes: ) meet down in Derby, CT every other Friday night or so. We would be more than happy to help out with your gauge installs. :)
https://www.turbodieselregister.com/forums/showthread.php?t=119987
I think that link will get you started, Moose
PS PM Me and I can get you the directions, if I can find them, if not I will get in touch with someone who has them.
Hi Moose,i'm up in Granby andwork 2nd shift,so coffee nights might be far and few inbetween. Thank for the invite,maybe sometime.
Wendsdays...
Yep, I work 2nd in Stratford, and I play Hookey to go to Coffee Nights :D I should be going to 1st shift in July. :D We do some weekend stuff too, Do you work weekends? Any rate if you still need some help maybe we can hook up on a Wendsday morning. Feel free to PM me if you need something, Just try to do it the day before you need it. Regards, Moose
