Since I have the Uconnect radio and frequently hitch up to a travel trailer, I really would like a backup camera.
I bought the kit from a Dodge dealer and am almost done with the install. It is not a simple installation! You have to remove pins from a connector below the tailgate and install in the new harness, route the harness down the frame rail by the main body harness - just labor intensive.
I am almost done, but have run into two snags. Below the main harness where it enters the firewall on the drivers side the instructions have you cut a rubber nipple and feed a small harness through to the cab to connect to the body module and radio. Haven't had much success here. Anyone know of a trick for getting this harness through?
After taking a break from trying to get the harness through the dash, I decided to enable the camera and connect in with the OBDLinkMX+ and Alfa OBD app on the tablet. I found a setting to enable the camera gridlines, but am not able to find a setting to enable the backup camera. Is it possible to enable the backup camera with the Alfa app or do I need to take to the dealer to enable?
Appreciate any and all help.
Thanks again!
Mark
Thanks again!
Mark
