WPowers,
I have to respectfully disagree with CKelely1 and suggest it's never a good idea to bring fuel... even less-volatile diesel... into the cab of an enclosed vehicle. The first time a leak stinks up your truck, you'll wish you hadn't. Whether or not you use a mechanical or electric gauge, it's far better to use an
isolator in the engine compartment, and from there, route an antifreeze-filled pressure line through the firewall into the cab.
He's correct about the VP44 fuel injection pump pressure vibrations wrecking havoc on delicate gauges. Definitely use a
snubber or small needle valve to dampen out these pressure waves, or whatever gauge or sender you ultimately use won't last very long.
Having had both a mechanical and now an electric fuel pressure gauge in my truck, I much prefer the simplicity and cleanliness of the electric. I repeatedly had small leaks develop with pressure line leading to a mechanical gauge and finally threw in the towel.
Personally I very much like the design, look, and quality of
Isspro EV2 fuel pressure gauges. Current EV2 gauges contain a red LED warning light which can be programmed (using a PC and
Isspro software) to illuminate when pressure drops or rises above a set point. Isspro gauges are manufactured, supported, and serviced here in the USA.
Best regards,
John L.
