I just got my FASS System from PDR and before I start the installation, I would like to get some input and suggestions on the installation. Since the topic of fuel systems has been a volatile one please don't start a flaming match here
1st, where is the best place to mount the unit on a long wheel base 3500 4X4 ?
2nd, Should I change the fuel tank pickup screen with a new one ?
3rd, PDR has suggested that I continue to use the OEM fuel filter/heater assy. since I live in a colder climate, Should I continue to use the OEM filter ?
4th Should I drill out the banjo fittings and what size drill should I use ?
5th, Where should I install my fuel pressure gauge for best results
6th Is there any benefits to hooking up the system to the cooling system to provide heat to the pump assy. ?
7th, In previous posts it was noted that some have installed a relay setup so that the FASS runs directly off the battery. What amp relay/ fuse is used what is the best setup for this.
I will be doing this outside and intend to unbolt the bed to lift it up gaining access to the fuel tank, yes I know this might be unnecessary step, but I want to make sure nothing is plugged up. And wanted any installation suggestions from someone who has already been there and done that.
Also I will be doing this in the next weekend where the weather allows and if anyone would like to come by and see whats all involved, please PM me for time and directions.
