I wanted an air bleed and a pressure port on my pump. There is a plug in the very front of the pump with a 10mm allen hex hole in it. Bosch did not want it removed so they put some type of locking stuff on it. It smacked it with the impact driver with no luck. Then I did somthing really dangerous!!!!! I made sure the pump was full of fuel and had no air in it. No air no fire. Then I proceded to heat that plug with a plumbers torch very carfully!!! Then I imeadiatly used my half inch impact wrench and out it came. I went to the hydrolics place down the street and they gave me a 18mm X 1. 5mm pich fitting to 1/4" pipe. It was too big so I put it in the lathe and made it a little smaller in diameter and I put it in with a "T" fitting with a bleader screw on top and a plug for a pressure gage later. I can now blead all the air out of the fuel pump easily with the hand primer and don't have to crank on the starter motor!! The best part is I am still alive and the pump did not turn into a hand granade
Treven. Oo.
Treven. Oo.
