Engine/Transmission (1998.5 - 2002) Installed bullydog 3's, And WOW
2nd Gen Non-Engine/Transmission Abreviations
Engine/Transmission (1998.5 - 2002) Automatic Trans Problems
Well the bombing flu got me on christmas day when I got some guages (Piro,boost) With a pod. So then I got them in and that max 20# boost thing bugged me. So I thought I have guages now what???? So I startd doing some reading here on the TDR and alot of people said that the ETH respond good with injectors. So started the search on injectors and decided to go with some 3's since I have 4" exhaust. So then I purched some in the classifeds off of JETPILOT, got a boost fooler with elbo, and when I got it all, One night I put them in and took for a ride and I was all :D :D Thought the clutch may slip, but I have managed to put 150 mi on it with the mods and my MPG is going up and not to bad of smoke but love this combo . Justin
Man sounds like a great set up! I am actually trying to do the same thing to mine. I just finished installing the injs, BDIII's, and have a boost fooler, but can't seem to hook it up. I believe that it is the wrong part. What kind of boost fooler did you get? If it is a BD would you mind telling me the part number, so that I can cross reference that to the one I have to ensure compatability? I'd really appreciate it. Thanks in advance and God Bless, James
sorry
I got mine from Practical Solutions. Mine plugged in at the rear if the intake (driver side ) rite behind the fuel filter housing, hope this helps. But if you need more just post it some body will know:D :D
Justin
Mileage Going Up?
JBrookshire
Don't want to rain on your parade... but is your fuel mileage going up on the overhead computer or by doing the math at the pump?
With an EZ and DDII's, my overhead says nearly 27mpg:eek: , mathematically, it actually lowered the mileage by 2-3 mpg over stock, but it's a ton more fun to drive:D.
The overhead computer gets an input from physical throttle position. With your mods it doesn't take nearly as much soot pedal to get the rig the same distance down the road, but you are burning more fuel in reality.
Loren
No No No
Why did you have to ruine my day with that:{ :{ :{ Never looked at it that way, But it looks good:D I guess the saying is rite
" You gotta pay to play" Justin
