Gonzo,
I experienced the same thing you did on my '04. 5 when I had Scheid Diesel rebuild my injectors and install 50hp Bosch nozzles. They were flow matched on the tester. The result was really incredible! Much smoother at idle and while running at all rpm's. Imagine the word "silk" here and you have the right idea, that's how smooth it is. Each injector is putting out the precise same amount of fuel as the others and it is pure joy to drive. A lot less noisy also. And then when the 6. 7 fluid damper is installed it is pretty close to heaven!
A truck may run good, have good pulling and towing power, even get good fuel economy and then when balanced injectors are installed it becomes a totally different truck in a good way. You really have to experience this to understand it.
Godspeed,
Trent
