Installed a direct reading oil pressure Gage, from the plugged port on the
oil filter housing.
Surprise; OEM gage nowhere close to actual readings.
Cold startup ( 80 degrees, Fl ) 80 psi, oem gage a little over 40.
As oil temp warmed, pressure dropped to 70's, oem gage stayed little over 40
Also the OEM gage does not follow RPM, Direct reading gage changes
quite a bit with rpm. 30 idle to 65 psi when engine is hot... .
Does anyone have the oil PSI vallues to compare to, I want to make sure
the Direct reading gage is functioning correctly... .
oil filter housing.
