I installed an edge comp today and took the truck out for a test run. Drove for a couple miles slow on the street, then I set it to level 5 and did a full throttle run up an on-ramp. At the stop of the ramp the truck abruptly shut off and wouldn't restart. Checked all the connections and everything seemed ok, so I called a buddy and towed it home on a strap.
I called edge and they said it was probably a fuel system issue. I probably need to bleed the fuel lines.
Do you guys agree? How do I bleed the lines?
Just don't tell me the injector pump died!
The lift pump was replaced last year. I haven't checked the pressure lately though because my gauge died. . I guess it couldn't hand the vibration of me leaving it under the hood!
