After 52K on my transfer pump using just an idiot light to monitor fuel pressure, I installed a Westach gauge. The first thing I noticed is that the pressure would rise to 9 psi when I turned the key and would drop to 0 as soon as the pump shut off. Once the engine was started, the pressure bounced around between 0 and 9 psi until the engine warmed up a bit. Then it would register 9 psi at idle and 6 psi at WOT. On a 300 mile trip this weekend, I realized that the pressure would often drop to 0. Typically when I was drifting down a long grade.
So my questions are:
1) Is this normal? (probably not)
2) Is there an easy way to determine if I have a problem with the pump or the gauge?
Thanks in advance for your help.
Doc
Doc
