That means I changed out the diff lube and put strong little magnets on the outside of the covers
. It took some persuasion to get the stock diff covers off, but they came. I used Mobil 1 lube front and rear. In the back, I used Trans-x brand of friction modifier. The problem is, I used HALF of the modifer that it says to (it's a 7-oz tube), and I have NO shuddering at all. I am wondering if this thing has too much modifier in it, or maybe it just needs time to work in? Before I changed the lube, my truck acted like it didn't even have a LSD-- I could spin one tire all day. Seems to be more of the same so far, but I am not sure. I will have to wait for slick conditions to test it.
By the way-- the stock gear lube was HIDEOUS after only 5500 miles. Lots of grey streaks and the break-in wear metal. The magnets were covered. I CAN'T BELIEVE that they say this is "maintenance free" and doesn't need to be changed regularly! Next time, I will swap in a mag-hytec and go to Redline synlube. I can totally see how much easier the Mag-Hytec would make this job.
I also did an oil change. I tried Delo 400 this time instead of Rotella. They both seem to be just fine. One more drain until synthetic!
