AfterBurner
All I can say is wow!
I've spent money on the most expensive inertia controllers on the market and even gave my oem controller
a few months to impress me. Nothing, and I mean Nothing comes close to this controller (except brakesmart, probably). There is ZERO lag in the trailer brakes, they respond exactly when the truck brakes do; it's hard to believe until you try it. No more waiting on the intertia controller to feel the deceleration and then jab the trailer brakes on.
Spent about 3 hours on the install. If you knew what you were doing, you could probably do it in one hour. I spent a lot of time scratching my head trying to figure things out.
The underhood part, tapping into the brake line was super easy. Trying to find a hole in the firewall was not! Ended up making a small cut in one of the grommets and passing the wire (from sensor on brake line to controller) through there. Unplugged and removed the oem controller, with the intention of putting the maxbrake in it's place, but it did not fit. So, I put the oem controller back in place and stuck the maxbrake in the usual spot above the right knee.
The install was really that simple. The oem controller is unplugged so I get a message on the EVIC everytime saying I need to service the controller. A visit to the dealer should be able to reflash the computer to "uninstall" brake controller.
Something to know before you put an aftermarket controller on a 4th gen - the trucks no longer come with the standard blue receptacle for an aftermarket controller. So make sure you get the right adapter when you pick up your controller. The maxbrake came with two adapters, one for pre 4th gens and one for 4th gens.
If anyone has questions about this install just let me know
Forrest
Forrest
