Archived Installed new clutch and wont go into gear
Archived Bully Dog Help!! truck will not start
Archived Truck ran out of fuel, how do I prime it?
Can you shift it with the engine off? Does the pedal feel normal?
It could be in the shifter. Loosen assembly and try it.
More info?
Good luck. And don't FORCE the issue, things get bent--bent things don't work.
I can shift through all the gears with the truck off and start out in ifrst and it will roll but the clutch feels extremely soft, check the hydraulic system does work but dont know how good???
They figured it out. The place that sold them the clutch sold them the wrong flywheel. The center section was too small and was rubbing on the dampener springs. They appreciate all the suggestions.
