and pressure is lower than the old one. The new pump is reading 12 at idle and 8 to 9 cruising, WOT is 4. The old pump was reading anywhere between 15 and 2, at idle, cruising, and WOT.
I let the old pump run on the bench today for 4 hours straight, no problem. I did remove the vanes, so it was just the motor.
I replaced the pump because after changing the filter, it wouldn't run. I had to rap on the outside of it to get it to run.
18 ft lbs converted to in lbs is 216, right?? I didn't torque the banjo's, just snugged them up by feel.
Why are the banjo washers rubber, could you use o-rings, or copper crush washers instead??
