Archived Installed new turbo and exhaust...now a noise
Archived ABS light/brake light after brake job...
Archived puddle of oil on the shop floor
Just put a HTBG, AFE and 4" exhaust on my truck. At a stop light, in gear, the truck has a bad vibration coming from underneath it. . maybe towards the trany or turbo itself. When I put it in neutral it goes away. It wasn't there yesterday before I installed everything. I noticed the oil return line running real close to the bracket next to the waste gate thingy. Also, the blue hose on the bottom of the turbo that loops around is right up against the inlet(metal) to the intercooler line. Is that going to melt?? Any suggestions??
Loosed the down pipe and pushed it away from the frame... sloved problem. Still not sure about that blue hose. Also, this thing really whistles now... that normal?? I assumed with the AFE and bigger turbo it would.
Not sure about your blue hose melting by my HTBG will "whistle" also. Did you get the 12 cm or 14 cm exhaust housing? I am running the 14 on my 01'.
