finally got it put in last nite , but not before it started to rain , so i don't have WOT data as of yet , and its snowing right now
i installed it in the stock location for the first test , used a 90* 3/8 compression fitting on the inlet and sawwed the banjo end off the stock line that fed the stock lift pump , no turning back now i suppose
used a 3/8 npt to -6 male on outlet , drilled it out to 21/64 and put a 100* chamfer on the inlet . as far as wiring i cut off the stock connector and attached the new wires to feed factory power to the pump . last but not least i switched the mounting studs off the stock pump as i didn't have the time to pull the factory bracket and drill it to except the rubber gromments supplied with the new pump . when i cut the factory bajo off i also removed the mouning braket that was attached to it as it is no longer needed and would have to be trimmed to fit between the compression nut and the lock for the stock fuel line connection .
i also ditched the banjo fitting coming out of the filter housing , only banjo left is inlet to injection pump as it is my only way at present to measure fuel pressure .
idle pressure is up 2 psi , cruising on the highway at 70-75 is up 2 psi and the first test i tryed with the PE in hot 3 and no va the pressure didn't go below 5 , but at about 70 the rear broke loose and kicked out because the road was wet , so that stopped all testing . i did put on the VA and it is still the same pressures as with just DD3's like prior testing also reveled .
to install
next will be to add a pre pump back at the tank before i relocate this one to the rear .
[This message has been edited by Mopar-muscle (edited 03-30-2001). ]
