... and it was a real PITA. Alot more work than installing on in my 01. 5 becasue of the vacuum pump. Took me several hours to figure out how to get the new serpentine belt installed. Total install time was probably around 10 hours, but I'm kind of slow with mods like this. Everything worked OK when I was done.
Why can't DC put a disconnect plug with all the electrical connections in one place and then just plug the ebrake harness into it? It would eliminate the need to mess with the ECM plugs, which could get real ugly if you screwed up.
I link the shifter mounted switch and the fact that the ECM turns the brake off when you stop.
Here's where I bought it.
http://www.klenger.net/dodge/general-reference/mechanicsville-dodge.html
Mud flaps and Line-X and I'm done.
