Installing a fuel pressure gauge.
Got the fitings, which line to cut for Auto Trans Sender
Idle to high
I'm planning on installing a 0-15 PSI fuel pressure gauge this weekend. Are there any special fittings I need to install the sending unit?? TIA
2000 24V, 6-speed, Flame Red, Agate leather, 3500 QC, 4X4, SLT+, 4:10's, LSD, AMSOIL Air/Bypass filters and all Fluids, 275 RV squirters, S. S. nerf bars, Line-x, Pyro/Boost/Fuel Press gauges.
We have about the same pickup,except mines white.
I put on 2 senders with a switch (before and after filter).
I needed 2 -4ANx1/8 fittings. I mounted them on the Test ports(Big Schrader Valves).
Removed the valve core. . screwed the -4AN on then screwed the senders on. Two wires to cockpit and to switch.
I used the SW gauge and senders.
Purchased the fittings at a local speed shop.
They were not available at any of the "conventional" parts stores. (NAPA,CarQuest etc. )
This worked for me. . Do a search for Fuel pressure and there is a good thread.
see ya
Fuzz
