I am going to install a toggle switch on the hot wire going to the lift pump. The purpose of this is to get fire to the pump when I change my fuel filter so that I can use the lift pump to fill the canister and remove as much air as possible before cranking her up.
Before you tell me I don't need to do this and how I can bump the ignition to do what I need to do, I had a TSB applied to my ECM for hard starts
. With this TSB the lift pump buzzs for only one to two seconds when the key is first turned on and does NOT run at all with a simple starter bump. Changing the fuel filter is a bear!
My questions are: What amp fuse should I put on the jump wire that will go to the lift pump from the toggle switch? How may amps does the lift pump pull? Which wire into the liftpump from the factory wiring harness is the hot wire?
TIA
TIA
