OK, here is my plan:
Going to buy a 22-gallon fuel cell and sit it in my extra wide/deep crossover box. I am still on the fence about whether to buy a steel one or plastic one... the steel might rust, but the plastic might be attacked by the diesel... but that's something I have asked Summit Racing...
I fully intend for this to be a pressured feed, not gravity... in other words, I will have a pump and filter feeding the main tank... probably going to either run a Carter or Holley for the pump... I already have a FS1251 filter and head.
I also (now) intend on installing a line from the main tank's vent to the fuel cell's vent... as well as the feed from the cell to the main tank... this should prevent pressurizing the main tank and causing it to rupture.
Now, what do you anticipate happening in the event the pump fills the tank? I was imagining the fuel filling the neck to the vent, then the pump simply circulating fuel back (through the vent line) to the cell... and not pressurizing the system... does this sound likely?
Any other hints or concerns? I am planning on getting the needed parts this weekend from Summit... would really like to hear from anyone else you has completed this using a pump to feed the main tank for the auxilary and see what problems were encountered...
steved
steved
