I bought my truck new in August of 2007. Had to put a South Bend clutch in after adding HP with the Smarty Jr. Having had a few knee surgeries on my Left knee and a replacement on the right knee. I have been wondering what I could do to make the South Bend clutch a little easier to operate. I have the HD organic clutch. I had the opportunity to work on a 2007, 5.9 6 speed Laramie equipped truck and it had the power pedals in it. I noticed that with the power pedals extended out, the clutch was much easier to operate because it added leverage to the pedal plus, even though I am long legged, driving around town, I had to have the seat more forward to fully disengage the clutch. Cruising down the freeway, I move the seat back some. I found a complete stick shift power pedal assembly and currently have it apart to clean and re-lube everything. The repair manual says you have to pull the whole assembly including the cast aluminum frame the pedal assembly is mounted to and pull the steering column. The parts fiche I have says the casting it the same for both standard and the power pedals. I am going to see if I can just change out the pedals in-frame and install the motor onto the existing aluminum casting installed in my truck. Will cover more tomorrow as that's when I plan to install them. By the way, it seems that most trucks have the wiring already installed to attach to the pedal motor and the switch. it is tucked up under the dash above the parking brake.
