Installing a Super B2 on my 05 Today
Di-Procol EGT & SRT-10 Problems
resonator for exhaust
I am installing a Super B2 turbo from Xtreme Truck and Trailer today. I also got a bully dog catback exhaust to put on as well. I will post results later on today or tomorrow.
have you seen KOOPDADDY
KOOPDADDY must be out racking up the miles on the new turbo set up. I guess when the newness wears off he might be able to :D find time to turn the computer back on. :) :--)
Just got it in. The exhaust was late arriving (3) days. The turbo install took about 4 hrs. Of which, I spent about 2. 5hrs just tightening the 4 nuts that hold the turbo to the manifold. The stock turbo uses 4 studs, 2 on the manifold and 2 on the turbo. The HTB2 does not have threads. So you have to make your own bolt and nut setup. The turbo is great, but the intake noise is rediculous. You cannot even hear the radio over the turbo noise. I have a MAC intake, I think I need to find a quieter version. I also went with Bullydog 5" exhaust. It is a little to loud, I will just install a baffled muffler instead of the straight thru. The filter minder is sucking shut, so airflow will need to be addressed. All in all, it is pretty nice, but time will tell,
I am running the Juice w\ Attitude stacked w\ the Quad fuel box. The Juice alone does not have enough fuel. EGTS are very low ~1250 full throttle to 60 or so. Lag is very minimal, and boost builds FAST!!! I do not know exact boost yet, as the attitude gauge uses the factory MAP sensor and it pegs at 36lbs. Even stacked there is ZERO smoke, I need more fuel, and my TST box is on the fritz. I should have the new downloader and hopefully that stacked should give me enought fuel
you have stacked a pressure box and the Juice, and not enough fuel???? :confused: :confused: :confused:
this is the first time i have heard of a 3rd gen truck stacked that is LACKING fuel... most of trucks stacked have way too much and have super-high EGTS
is the juice box not that aggressive??
And when you say not enough fuel, what do you mean? Like to enough to spool? or not enough to smoke?
crazy man, just crazy
